Hi everyone, I bought a 8T hard drive on Amazon that arrived in a thin bubble envelope inside a book box contained in a larger box with some paper inside.
Being placed on the bottom sure it has taken a lot of bumps considering the damaged outer packaging, what should I do? In the past they have used much stronger packaging.
I have to put important data in it. Smart data already says it had a problem with heads not parked properly: unsafe shutdown count.
HDtune error scan was ok for now.
https://ibb.co/cvBwF5N
I have read on various forums that even if it was perfect, a disk that has suffered improper shipping and packaging is more likely to encounter errors in the future
I have an identical hard disk but it does not exceed 30 degrees Celsius / 86 F as opposed to this one that reaches 37 Celsius / 98 F
What should I do?
What should I do?
