Hard drive appearing then disappearing
ninjapanda909
Commendable
Aug 16, 2017
16
So I got a new hard drive, not a back up, and put it in my computer, installed Windows then turned it off and on. That's when my PC didn't detect my hdd and just left me to the boot menu where I can only pick my disk drive. Any suggestions?
Double-check the cables are in good, and if that doesn't work, use a different SATA cable to connect it to a different port on your motherboard. Also use a different power connector on your PSU. Just to be sure that none of the connectors are burnt out and causing the issue.
If none of that fixes it, the drive is most likely dead.
