Hard drive cleaning tools
jagzc
71
HEy all
I am just about to sell one on my external Hard drive and i was wonmdering is there some kinda of app that will clean it so files cant be restored ?
thanks for any help given
search for shreders on the google.
Simply deleting or shift deleting will not help. Even if you break your harddrive in pieces , it is recoverable.
The way these shreders works is they will write some garbage data on the entire drive and then delete it and then rewrite it and delete it. A good shreder does it for some 15 - 20 times , which makes original data virtually impossible to recover.
Lost of antiviruses have inbuilt shreders too.
I have always run a weekly cleanup with CCleaner software.All you need is the built in defrag, check disk and disk cleaner.
