Thank you all in advance for any possible help/feedback/enlightenment.
I think I have the ultimate computer hardware riddle--
Was running a 1TB Seagate Barracuda (SATA 3.0) for around a year when I decided to buy myself a 240 GB SSD (over a year ago). Installed the SSD and my external immediately became wonky. Tried to get it to work by cleaning/fixing but after a hard crash the system no longer detected it. Tried different power ports and SATA ports and SATA cords. No dice. Figured it had simply toasted itself.
Around 1 year later (last month), as my SSD filled up I decided I'd like to try the 1TB again. Plugged it in, booted, it worked!! Couple hours later, hard crash. On subsequent boots it was undetectable as previous.
So I decided I'd buy myself another 1TB drive (WD Green 7200 SATA 3.0). Installed the drive and booted. Nothing detected 'cept the SSD. Hmm.. that's odd! Must be a faulty motherboard right?!
Tried swapping some power cords and SATA ports and suddenly on boot I get ONLY the 1TB new drive detecting. No longer SSD either. SSD has windows so I can't even boot up anymore (I'm posting this on my laptop).
I figured- hmm odd, maybe it's a PSU issue. So I swapped all 4 power cords, tried 3 different SATA cords, and swapped into like 4-5 different ports on the MOBO.
No matter what combination of whatever I used, I kept getting 100% reg on the CD/DVD drive and 100% reg on the brand new 1 TB hd. I can't get ANY signal from the SSD or the old 1 TB drive.
My mobo has 2- SATA3.0 and 4 SATA2 ports. PSU is only 400W, so there was a tiny thought in my mind that I was underpowering multiple drives, but when unplugging literally everything and cycling drives, the SSD still doesn't work.
TL;DR-- My computer is only detecting 1 of 3 of total SATA drives. It's not a PSU issue, it's not cables, it's not faulty drives.
My thoughts:
1) Underpowered PSU or faulty power plugs -- Nope, not logical based on testing.
2) Bad mobo ports or bad SATA cords -- Nope, tested out
3) 1TB was faulty -- perhaps, but doesn't explain recent swap
4) Got some crazy power spike that fried my 1TB, then my SSD, but not my brand new 1TB yet -- very unlikely
5) Weirdest virus you've ever heard of -- ?
6) Some sort of wacky SATA controller bug issue -- This seems the most likely, but I have no idea how to test... This is the weirdest thing I've ever heard of and all my other techie friends are totally stumped.
Thanks again for any potential help!!
-J
My thoughts:
-J
