I have been having some problems with my old hard drive lately. It is an IDE drive. I have three hard drives in my system. A 75 GB boot drive which is working fine. A 450 GB drive which just disappeared, and another 450 GB that is working fine. I have been having problems with the D drive, the one that's broken, for a couple days now. I started windows 7 ultimate one day and startup got stuck on the starting windows screen. Then it went to a screen that said it needed to check my D drive for consistency. I let it check my D drive for about a half hour and then when it was finished it locked up and I had to do a hard shutoff. Then I turned on the computer again and it went to the same thing, but this time I cancelled it by pressing escape a couple times. I looked into this a little and I figured that my hard drive had a dirty bit. I did a little more research and figured out that I needed to run a script in CMD called "CHKDSK /f /r D:" I did this and let it run for two days straight. After two days it said it was on a certain file I cant remember the number it was, but It was stuck on that number for three days and I assumed it had failed. I closed CMD and tried to open the D drive in windows explorer. It loaded for a couple minutes then the computer locked up when it was near finished and I had to do a hard shut off. I turned my computer back on and it said what it did before, checking for consistency on D. I cancelled it and windows booted. Then I opened up explorer and D was gone. It's a 5 year old computer so I guess the hard drives have lasted pretty long, but I want to get the most out of it. Any ideas?
