OhSoDevious :
Tumeden :
Good suggestions from Luminary above, If you're doing a lot of recording i recommend grabbing a smaller SSD to run your OS/recording program on, and use the HDD for file storage of videos - you'll see a huge performance gain with load times, and recording.
What is your budget for upgrades?
My budget for a hard drive is $130 Does hard drive speed mean much?
That all depends on you, really.
- A HDD can load windows from off, to fully loaded in 50 seconds to a minute usually.
- A SSD can load windows from off to fully loaded in 15-25 seconds.
- When it comes to gaming the only huge difference between HDD's and SSD's are load time.
- When recording; SSD's perform much much better, and in some cases allow you to...
