Hard drive from Newegg not in box?
jdbaker82
102
Just came in bubble wrap with no manual or cables is this normal?
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
Onus
Yes, that is normal for an OEM drive.
It is the Retail package (if available) that will have a product box, probably a manual, mounting screws, and maybe even a SATA cable. Most mobos come with enough cables, and cases should come with screws, so that all those things aren't needed.
Jascomputerguy
30
OEM is very tricky because it really isn't written in black and white what is coming in your package! Was there anything wrong with the drive except it had no cables or manual?
shortstuff_mt
Glorious
Yes, that's why the OEM drives are cheaper. www.zipzoomfly.com does a better job packaging their OEM drives. It's still just the bare drive, but they package the drive in a little foam box that protects it much better than the bubble wrap. Something to keep in mind when you order hard drives. I've had a few drives come DOA from Newegg, but never from zipzoomfly. I attribute it to superior packaging.
Prescott_666
166
The last term in the name of the drive says it all - OEM. With the OEM pack you get the drive and nothing else.
With a Retail pack you would have gotten more. Exactly what you would have gotten varies but I don't think it includes a cable. You get maybe a CD with disk management software and drivers for system whose BIOS can't recognize a drive this large. And maybe extra jumpers for setting Master/Slave/etc
Similar threads
