Hello,
I have a 2Tb WD red hard drive which contains all my movies. It was formatted as NTFS on windows 7 and has been filled using a sata to usb 2.0 adapter while I was waiting to build my htpc.
Now the htpc is built and running windows 7 on separate hd but when I connect my hd to it using the hot swap bay (sata), it tells me I need to format it.
When I check on disk management I can see the hard drive but it has a 250Gb Raw partition and a 1.6Tb unallocated partition.
When I connect the hard drive to one of the usb 2.0 port using the adapter, the htpc recognise the hard drive fine and I can see the 2Tb NTFS partition in disk management?! This means the hard drive is fine and not damaged?
Is there any way to fix this issue and get Windows 7 to recognise the hard drive correctly when connected to the sata ports of the mobo?
I really don't want to format the hard drive since it has 1.6Tb worth of movies!!
I hope I am clear enough if not ask me.
Thanks in advance.
Thanks in advance.
