Hard Drive Interface Question
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I have a question for some of the more "knowledgable" of the group:
are EIDE hard drives and IDE Ultra ATA100 hard drives the same ?
What I am getting at is I can get a good deal on an IDE Ultra ATA100
hard drive and was wondering if I could use it in my system. Thanks!
Mike
Dimension 8200
2.53 Ghz P4
512 Megs RD-RAM
Windows XP Home SP1
Yep.
Will work fine. The ATA133 drivers are faster, but the difference is small
and I'm not convinced you'd ever see the difference.
Better be an incredible deal though. Anything over about 60 cents a
gigabyte is too high.
Tom
"Mike Smith" <Mike@SunnyOrlando.com> wrote in message
news:3jqbk017runv99cj70s924elh2bp9u1ido@4ax.com...
> Mike
> Dimension 8200
> 2.53 Ghz P4
> 512 Megs RD-RAM
> Windows XP Home SP1
On Mon, 13 Sep 2004 15:11:16 -0400, "Tom Scales" <tomtoo@softhome.net>
wrote:
>Yep.
>Tom
Thanks for the prompt reply Tom. My buddy has a 200 Gig drive, the
one I was talking about, that he will sell to me for $115 which I
though was a good deal. It's never been used and I am in need of
something extra besides my current 80 Gig hard drive.
Mike
If you trust your buddy, go for it. However, you can find brand name 200GB
hard disks at retail for the same or less, if you can deal with rebates. At
least with a retail disk you have the manufacturer's warranty if something
goes wrong.
A tip: If you do get a bigger hard disk, you should consider making it your
primary hard disk. Depending on what type of hard disk your 80GB is, the new
disk may be significantly faster. Also, there is a theoretical performance
advantage to be gained from using a larger hard disk, since more of your
operating system will be stored on the outermost tracks, which spin the
fastest. I can't say whether this translates into faster performance that
you can actually notice.
Another advantage of a second hard disk: You can store your page file on the
second disk and gain some performance advantage.
"How to configure paging files for optimization and recovery in Windows XP"
http://support.microsoft.com/default.aspx?scid=kb;en-us;314482&Product=winxp
And, of course, you can use a second hard disk to backup your system. Enjoy.
Ted Zieglar
news:iatbk097lk66vtlu3v21bajib8a98uop02@4ax.com...
> wrote:
> >Yep.
small
> >Tom
> Mike
Also don't forget your 8200 won't support over 127GB. So, that's all you'll
see unless you add a PCI card that supports a bigger drive.
Tom
"Ted Zieglar" <teddyz@notmail.com> wrote in message
news:1095104935.a7wVzdj30GU4yWoIh6paXA@teranews...
> At
> goes wrong.
> your
> new
> the
> XP"
> Enjoy.
> Ted Zieglar
>> wrote:
>> >Yep.
> small
>> >Tom
>> Mike
On Mon, 13 Sep 2004 15:50:45 -0400, "Ted Zieglar" <teddyz@notmail.com>
Ted, that's an informative link. Thanks!
Mike
news:sj9ck0572o3s7eao2nf2fg912obdr21e8q@4ax.com...
>>the
>>XP"
>>Enjoy.
> Mike
Promise controller cards:
http://www.newegg.com/app/SearchProductResult.asp?Submit=Go&DEPA=1
Stew
On Mon, 13 Sep 2004 17:18:34 -0400, "Tom Scales" <tomtoo@softhome.net>
Nice heads up Tom! I told my buddy this and wanted him to lower his
price 😛 He told me that if I have Win XP with SP1 installed it
should see the entire hard drive minus about 15 Gigs. Seeing how he
knows just a tab bit more about these things than me, and I don't know
a whole bunch, is that correct ? I googled this and have found
conflicting reports. Since my computer is a bit older it would not
surprise me that I could not get it to recognize a real large hard
drive. Thanks for all the information.
Mike
news:nc9ck0lggqhrnun0f69c954op32797a3f1@4ax.com...
>>you'll
> Mike
I've heard this, but think it is an urban myth. Can't see how XP could
overcome the limitations of the controller electronics, but what do I know!
Tom
