Hard drive issue (not sure where to ask)
Frankenchokey
13
I'll try to describe this the best that I can.
I have a couple hard drives in my PC. The last time I had installed a new HDD, I took the power supply from my DVD drive (since I don't use it much) to use for the new HDD. Yesterday I received a new power supply (4 pin molex to Sata converter), attached it to another cable and connected it to the power supply
It didn't seem to plug in all the way, but, I could not force it to go any farther in. I turned on the computer to test it and I smelled a kind of chemical/ burn type smell. The dvd drive did not work, I used a different power cable, and even switched out the power cable from the HDD in question to test the dvd drive (I took the power cable from the HDD and used it on the dvd drive).
The dvd drive is absolutely dead, but now my HDD seems to be acting weird. Games and videos aren't playing properly, all my data is still there, and I don't see any issues with the mother board (as in, no blown capacitors). Games seem to work perfectly fine on my primary SSD (ie. Arkham City on my HDD froze on the Nvidia screen, Skyrim on the SSD played perfectly).
Is there any there reason or explanation for what may be happening? It doesn't seem like a power supply issue, the bios seems to show that the PC is running at normal temp. I even double checked that the Graphic Card is properly connected. Could a short circuit have damaged only one specific HDD?
"Is it possible" ?
Anything is possible.
"...smelled a kind of chemical/ burn type smell..." indicates something is burnt.
Could be the drive connector, could be the cable, could be the PSU, could be the motherboard port.
Is it possible that it messed up the hard drive? All the sata plugs show up as connected in bios so I don't think that's an issue. I'll double check when I get home to see if the cpu and the graphic card are working properly, but I think they are from what I can tell. Fortunately the HDD just has games and videos on it so I wouldn't really lose anything too drastic.
"Is it possible" ?
Well, all my drives are connected to the same power cable, I think I'll move the Sata cable to a different spot and see if that helps.
I think it cooked the old dvd drive. I switched sata ports from where it was to a new spot, seems to be working ok.
