Hard drive light stays on and system slow
Zaibi48
hi when ever i turn my laptop its hard drive light stays on and system is slow but it wont happen on every startup
but i face this problem 95% times
Run a disk check, there may be a utility in the BIOS or the drive vendor should have a program you can run. Don't just run checkdisk from Windows, run a specific program from the drive vendor to scan the disk.
You will probably need to replace it and install Windows clean on the new drive. It may be possible you can clone your current drive to the new one, some drives have a utility for that, if not you can use Macrium Reflect. There is a free version that works well.
