Hi guys,i have a serious problem, my hard drive probably died. how that happend? like that:
i bought a kit , its a "USB 2.0 TO SATA/IDE CABLE" from DYNAMODE company maybe some of you know it.
i decided to buy it, because my friend had one, and i needed one too, he let me use his kit, until i will buy my own.
so, i bought one, and on the first attepmt to use the kit, i pluged it into my second hard drive.
when i pluged the power adapter, it did some weird noise, like a non stoping beep noise, and when i unnplugd it, the noise is no more.
ok i plugd it again, and touched the hard drive to feel it if the motor is spining, but it wont, its only get hoter and hoter on the chips and the motor of the hard drive wont starts.
than i realized that probably this power adapter, burned my hard drive chips or somthing, that starts the engine.
i tested it, i took the moled connection and tested how much volts it outputs, well, on my friends adapter and molex, it give 13-14V ~ and 6.5V ~ , ok, just how it should be.
then i took mine, and tested it, and it OUTPUTS 17V~ and insted of 5-6V~ it OUTPUTS 16.5V~ in the molex connector that is connected to the power adapter that converts the 220V to hard drive volts.
so, insted of recivind 5-6V ~ the cips on the hard drive recievd 17V~ and that BURNED them i think.
my questions are like that:
1) of course i will go to the store and demend them to change the kit, but what with the hard drive? i saw on the internet and read on some places. that many peole change the chips, or the whol green chip borad on the hard drive them selfs, is it possible? (i have the knowledge to do it) ? can it be done? to change only that chi that burned? and wont start the engine?
2) will the store have to fix my hard drive because of their kit that they sold and burned my hard drive? or the company that makes this kit is the one to blame? after all my data is not lost but i cant start the motor, so it dead for now.
3) will the sotre needs to send it to try and fix it? or recover the data? or half i pay and half they pay to do this? i need some advise please.
thank you, sorry for the long text.
