Hard drive not functioning properly
Jul 17, 2018
4
Ok, so I have recently built a new PC. For storage, I installed a 2tb WD hdd and a 120 Kingston ssd. The issue is that my computer seems to only be utililizing the SSD for storage.
Here is the view of drives from file explorer:
https://gyazo.com/cf6d6850246f4524b330b3d1a846b7fe
Here is drives from disk management:
https://gyazo.com/82775dcafaaf2343b40c4cc4fca771f2
However, it seems that the hard drive is in someway being recognized by pc due to its appearance in
The properties of the C: drive:
https://gyazo.com/d7e64e5cfb85fbe8a8ac41d26526cc4f
My devices:
https://gyazo.com/aae9845f6aa0b4db49055fe8c4494718
And Western Digital Date Lifeguard Software:
https://gyazo.com/21dd936000f155d0421dbf8b90fa8311
It also appears as a bootable drive(I think that's the term) in the BIOS, but nothing changes when selecting it as that.
I would appreciate any help in getting my harddrive to work correctly. I have already reset windows and replugged in all cords of hard drive to motherboard, as well as replacing ATA cable. Thank you for your help!
I downloaded the partition wizard(not sure if that is the one you wanted). what exactly would you like a screenshot of?
whoops, I accidentally posted a screenshot of the wrong thing in the original post. this is what my disk management window looks like
https://gyazo.com/c54103a771fe30159cf35a3d8b4088a5
there is not an option to select the WD Drive, and when you view properties of the C: or D: drive it shows both drives as seen in
