Hard drive not seen when connected via SATA but is seen when in USB dock
Mr Inohk
21
I have a WD Blue WD10EZEX 1 TB drive that has Windows 10 installed on it. When I connect it to any motherboard (tried 3) via SATA, the board doesnt see it at all. When I connect it via a Thermaltake BlacX Duet USB Dock it works fine, and will even boot. Any suggestions as to how I might get this thing working on SATA again?
I am totally at a loss as to what else the problem could be. The only thing that makes sense to me is if you aren't plugging in both the data and power cable. Or you are plugging it into a SATA port that's turned off in the bios. Last option is if the drive is dead, which it can't be if it's seen in the dock.
Let me be a bit more detailed then
When connected via SATA, the BIOS will not detect it. The drive receives power as it would normally and spins up just fine, but the BIOS acts as though nothing is plugged in and will simply boot to BIOS configuration or say there is no bootable device (depending on the board). Under the same circumstances all of my other drives work perfectly fine, in the same ports and everything.
When connected via a USB dock the drive is detected and functions properly. The BIOS will boot into it if no SATA drive is available or it is selected manually. The OS is usable.
The system specs seem to be irrelevant as i've tested on 3 separate, very different, systems with the same results on each. Here are the specs of 2 of the 3 systems
System 1 (the system this drive came from)
Mobo: Gigabyte F2A78M-HD2
CPU: AMD A10-7870k
RAM: 4x2 GB kit G.skill Ripjaws X
GPU: nvidia GTX 750
System 2 (my personal computer)
Mobo: Asrock H97m-pro4
CPU: Intel Core i5 4690k (I'm aware the above board can't overclock; I made a mistake)
Ram: 2 separate kits of 4x2 GB G.skill RipjawsX for 16 GB
GPU: nvidia GTX 950
System 3 is a Mac pro of sorts (I think 2012? It's not the trashcan) and remains a mystery to me since I have no access to it myself. I tested the drive on it under the supervision of it's owner.
EDIT: There are no M.2 drives in any of the tested systems. Thats a bit out of my budget
It was partitioned and formatted during the Windows 10 installation while plugged into a SATA port. It is also completely undetected by the BIOS.
I have tried to move the data to another hard drive. It works-ish. The OS boots but eventually stops at a black screen with a mouse after the loading animation finishes
EDIT: Move the data while on the USB dock I meant
I've gone through and done that. I don't think I'm plugging it in wrong since I keep plugging in another drive in it's place (for unrelated reasons) the same way with the same cables and everything
The drive was functional at one point. During that time it was in normal use as the boot and storage drive. It only started doing this after being flown overseas. I didnt think that would be too important considering the drive still works under USB
Yeah this thing has baffled me for weeks now. Thats why I came here in hopes of some insights into what might possibly be wrong
Ok, try rightclicking on my computer-->manage
Then Storage or discmanager.
Does it show up as a uninitialzized disc?
If so, try right clicking the drive, not the volume.
Go to properties an tick on "allow caching of files and media.
There should be two boxes, i am talking about the top one.
Anyways that worked for me. Hope your problem was or is similar
He's mentioned it isn't seen in the bios, so that won't work. Until the bios sees it there is nothing you can do in windows to make it work.
A thought just occurred to me. Have you tried a different SATA port on the board? I haven't looked up your board to see if this is the case, but some boards disable SATA ports if an eSATA drive is plugged in. The odds of that happening on two different systems is pretty low, but I'd look at trying different ports to see if that helps.
I've tried multiple SATA ports on each board, and no eSATA drives are plugged in either. I even try switching the ports between the drive I'm using to boot windows and the broken(ish?) drive.
As a temporary solution I've used the USB dock to copy all of the files from the broken drive onto another drive I had laying about so the person who owns this has something to work with until we figure out whats up with this one
