Hard drive not showing up
frydenlund.joachim
4
In my BIOS I see my hard drive showing up. When i go to windows i can't find it under "This PC". Only my M.2 SSD. I open "Disk Management" and can't find it there either. Only my "C Drive" and "System Reserved". I checked that the SATA cable and SATA power cable is connected and it is. I put my finger on my Hard Drive and i feel it vibrating but i can't find it in "This PC". I went to "Device Manager" and i found it there and tried to update the driver but it is already updated to the latest version.
Hello,
Well you need to assign that drive a letter ( if it is a partitioned drive) and to format it if it is new ones.
Right Click This PC and click Manage.
Choose Disk Management from left list.
On the right side you will find all of your drives
Assign a letter or format it as I said above.
Regards.
Hello,
Regards.
What motherboard is this?
What is the specific m.2 drive?
Most motherboards disable one or more SATA slots, depending on the m.2 drive.
