Hard drive or virus . either way its goosed
stuarthcraig
Hello all... I am after some good advice form people with experience of hard drive issues, causes and repair ??
Hope you can help as i am now at a loss.
I have an acer 5553g laptop. Used mainly for internet, few presentations, a few pics and to link with tablet.. like drop box, google + . i player.. that sort of thing but not overused. Its 2 years old.
I have Never dropped it and been extra carefull with it.
On Sunday it appeared to die. what i mean by this is that i could not find the operating system nor the hard drive although i can still access BIOS by pressing f2 or multi bios by pressing F12.
This is the message
INTEL UNDI PXE-2.0 (build 083)
Copyright (c) 1997-2000 intel coporation
FOR ATHEROS PCIE ETHERNET CONTROLLER V2.0.1.9 (12/15/09)
CHECK CABLE CONNECTION !
PXE-MOF: EXITING INTEL PXE ROM
OPERATING SYSTEM NOT FOUND
This is what i have done so far. At first a couple of times it did go automatically to system repair which i left on overnight the first time. This did not work nor did it worked the second time. After that it did not come up automatically.
I went to the F2 Bios screen and noted that my IDEO model name and serial number were not shown just the HDD but no name.
Next night i manually opened the CD tray and put a copy of windows 7 in so that i could use repair from disk.
i went to F2 and changed the BIOS to point to the CD.
This did fire up but running the repair didnt work tried several times, a message came up asking if i had recently installed any hardware (which i had not) then said something about contacting manufacturer or administrator.
The memory check and other options didnt work... i di have a change to attempt to copy boot drives .. but when i accessed the folders from the disk i didnt know what i was looking for really.
I changed the bios back . Next night after reading more on line in the day I pressed F12 before to make sure the BIOS was pointing to harddrive and at that point i could see the toshiba hardrive name and the model number so i thought great i have a chance. It did not display on the F2. I tried this so that i could try to access the partition that had some acer recovery utilities.
The title at the top was Phoenix securecor(tm) set up utility
When i exited I got the same messages as before.. check cable etc
So i then decided to start up again pressing alt F10 a number of times to try to get to the erecovery. It did start up and I thought i has a chance to recover everything... i waited in anticipation for 30 mins.
Then another error message :
NAPP-KM:NAPP7.exe - Application error
The exception unknown software exception (0x000000d) (exact words)
occured in the application at 0x1005a6d8
click ok to terminate the programe
The ring cursor was still spinning but no hard drive light anymore so i waited 20mins then pressed cancel
Upon starting the laptop again i went to both F2 and F12 and this time i found that the IDEO Model name and Serial number in F12 had disapeared.
I cant help but think.. when i opened the erecovery some vicious virus saw it as a doorway and decided to do the same as the original sector of Hard drive (i have been told that some viruses if bad can stop your Bios seeing the zero sector)
I am now completely at a loss.
Do i simply just buy a new harddrive and start again, bearing in mind that windows 7 was preloaded by Acer and i am one of those guys who just didn't get around to full backup (low use my excuse) so have to get another copy of windows 7.
Or is there another few things i could try ? Given that this week was already a bit of a learning curve.. simple solutions or in lamen terms would be good... or if it is technical.. step by step.. i may know a little bit but not enough
Hope you can sort me out?
Thanks Stuart
All hard drives fail sooner or later just because of the way they work and the delicate moving parts they contain, not to mention failure of their integrated electronics, so jumping to conclusions about malware infections may be unfounded.
Hard drive failure is inevitable at some point, that's for certain.
You can test for drive failure with the manufacturer's diagnostic software which doesn't need Windows. It loads from a bootable CD which you can create from the downloaded ISO file with a free app called IMGBurn.
Links to manufacturer's diagnostic software for DOS are here: http://www.tacktech.com/display.cfm?ttid=287
IMGBurn is here: http://www.filehippo.com/download_imgburn/
You can run different diagnostics but I really have a feeling your hard disk just died. Really don't think this is a virus. So I think your option is to buy a new disk. SSD prices have dropped a lot recently so you can see this as an opportunity to step up to SSD performance if you can afford it.
I also understand you lost (or didn't create) your recovery cd. In this case you can contact Acer and they'll be able to provide one for your specific laptop but I think there's a fee for this (but still will cost less than buying a brand new Windows license).
