Hard drive problem
Hh1123
5
I have 2 hard drives showing up but only the 118 GB one is being used, and i cant figure out how to use the second hard drive "New volume (E:)" which is 1.81 TB, I have looked everywhere but cant seem to word it right to find a solution.
The drive is accessible right?
You should be able to access it and store some data over there.
You can start with just moving music, pictures, videos over there. You can do so with simple drag and drop (copy/paste).
As for your applications, you will need to uninstall them and reinstall them back on your E: drive. During the installation process, you will be asked where do you want to install the specific tool.
You have two separate, physical drives. So, you can expect that data after one of the drive is filled up, all the data would go to your secondary one.
Here are a couple of articles on that:
http://www.howtogeek.com/172545/7-tips-for-using-multiple-hard-drives-with-windows/...
Hh1123
5
Hi here's a screenshot of what it looks like: http://puu.sh/rhIGd/d907437abf.png
And the drive has been there since i bought the computer.
Hope this helps.
http://www.pcadvisor.co.uk/how-to/windows/how-install-software-second-hard-drive-move-program-files-folder-in-windows-3500581/
Hope this will help,
D_Know_WD :)
