Ok, I have a problem that I have literally exhausted all available options to me, so I need the advice of someone that's a lot more knowledgeable than I am.
Two days ago while my father was using my PC he had a dialogue come up that said the system needed to restart for updates to be installed. He clicked the restart button and the computer never came back on.
I spent an entire day trying to find out what the issue was, and came to find that almost the entire boot folder was being listed as unreadable and corrupt. I have tried using the Windows 7 recovery tools, the expanded tools available on the install cd, and I have even gone through the process of rebuilding the boot files through the command prompt.
Nothing else on the hard drive is having any issues at all. all the files and programs are still there, but Windows will not load at all. It keeps stating that bootmgr is missing.
I have researched what is going on extensively, and I have tried everything I can think of, and I even found that even a clean install of the operating system may not work.
I thought this might be some type of virus, as the only files that seem to giving me issues are the ones located in the boot section of the Windows folder, but now I am worried that it might be a hardware issue.
I was thinking about taking a hard drive out of an older computer and using that one and doing a clean install of windows on that one and using my old drive as data storage, but I am not sure if that is even viable. Any suggestions or help would be greatly appreciated.
