Hi guys i need help,been running out of ideas, i build my computer myself and i just recently bought a new computer case and rebuild it over into the new case everything worked fine then windows 10 started crashing i was not able to repair windows 10 and i was also not able to format and install windows 7 back on the primary hard drive i the removed the primary tried the same with the secondary which is a new hdd and the same nothing works and after trying to boot windows 7 i started to get the blue screen drive static failure, then i bought a new ssd and installed windows 7 that worked but as soon as i plug my hdd in windows gets stuck on the the starting windows screen and eventually i get a blue screen again, as soon as i remove the hdd it works again and this happens to both my hddrives. computer specs . i just got these error codes in windows restore Windows Fails to Start Multiple Times. Err Codes: 0x1f and 0x490 etc
Intel i7 4,00 ghz cpu
gtx 950 paulit graphics card
12 gb kingston ddr 3 1666mhz hyper x fury ram
toshiba 1 tb hdd (new secondary)
seagate 500gb old primary
new ssd to test samsung 750 evo
600w powersupply be quiet
asus z97 pro gamer motherboard
