Hi there.
Im wondering if anyone can help me with a problem in having
Here goes..
I aquired a new hard drive off my friend
Its a 15GB IBM 7200
The jumper settings on the back are 1 on Master and 1 on 16 cycles
Ive put it in my machine and formatted it, Installed Windows ME
and all my drivers for my graphics,sound etc.
When i go into device manager i have an exclamation mark next to
Primary IDE Controller (dual fifo)
In the properties it says
Either the device isnt present, not working properly or doesnt have
all the drivers installed
Ive tried updating te drivers [off ME disc & Mobo disc] but no joy.
Also when i go into system properties / Performance it says:
Memory: 256.0MB of RAM
System Resources: 76% free
File System: Some drives are using MS-DOS compatibility
Virtual Memory: MS-DOS compatibility mode
Disk Compression: Not Installed
PC Cards [PCMCIA]: No PC Card Sockets are installed
In the white box it says:
Compatibility-mode paging reduces overall system performance.
Drive C is using MS-DOS compatibility mode file system.
I know this is not ok, and the only thing i can think of that it is,
is that my IDE cable isnt a fast Hard drive one, but it is thinner than a normal one.
[Ive been told that they are thinner ribbons].
Any help would be much appreciated thx.
Athlon 1.4Ghz 266
K7S5A ECS Motherboard
256MB DDR RAM
IBM 15GB 7200 HD
Geforce 3 Ti200
Windows ME
Here goes..
Its a 15GB IBM 7200
Athlon 1.4Ghz 266
256MB DDR RAM
IBM 15GB 7200 HD
Geforce 3 Ti200
Windows ME
