You can try a Sysprep of your HDD. Below works for windows 7 and probably is the same for win8. It's worth a try.
To do this, go to C:\Windows\System32\Sysprep\sysprep.exe, check 'generalize', select 'OOBE' on drop down menu, and 'Shut down'.
When your new PC boots off of your old HDD, you'll get the 'out of box experience' screen, asking you to create new user account. Just call it anything and after that's done, you can log off and switch to your main user account.
Once you're logged in with your main account, you can safely proceed with deleting the newly made account in Control Panel > User Accounts applet
What sysprep does, it basicly gets rid of all platform specific data such as drivers and configuration files.
