hard drive showing as other device and not in disk management or file explorer
kwarde
55
I can not access a new hard drive in my computer. I have tried several things but still stuck. I suspect it is some driver issue but not sure what next steps i can try. Details below...
symptoms:
- I can see the hard drive in the bios
- I can not see it in disk management (nor the file explorer)
- I can see it under device management as an "other device." i can not seem to update the driver (automatically)
physical checks:
- I tried different ports, sata cables, and power connectors - all with known working combinations from the other HDs
- I tried the HD in a different computer and it worked perfectly
i have tried:
- updating the bios
- reinstalling windows (3 times or so)
- searching WD website for drivers or utilities
- switched from IDE to AHCI and reinstalled windows
computer specs:
- OS: Win 10
- Motherboard - Gigabyte GA-H55M-S2H
- Processor - Intel i3-330
- SSD - boot/windows Corsair Force Series 3 CSSD-F90GB3-BK 2.5" 90GB SATA III Internal Solid State Drive (SSD)
- Hard Drive 2 - storage Western Digital AV-GP WD5000AVDS
- Hard Drive 3 - storage WD 2 TB AV-GP WD20EURX <<<<< HD Can not see
Hi there kwarde,
One thing you can do is to go to your MOBO's website and update all the drivers, especially the SATA ones.
Is this a new drive? Do you have some data stored on it?
In case this is a new drive and it is not partitioned and formatted, you can boot up Ubuntu from a flash drive or a CD, partition and format, switch back to Win and see if the drive would be recognized.
Thread on Ubuntu Live CD: http://www.tomshardware.co.uk/forum/267999-32-recover-data-mode
Let me know how this goes,
D_Know_WD
Hi there kwarde,
D_Know_WD
Hey D_Know_WD,
Thanks for the reply. I have tried the MOBO updates and no luck. It is a brand new drive. I have plugged the new drive into another Win 10 computer and formatted it, even though it was recognized right away.
Would taking the Ubuntu step do anything more than I have already done?
Any other suggestions?
Thanks
So going to Ubuntu was the right path. Once there, i finally could see the drive but not access it. i deleted or removed the partition and restarted into windows 10 and it was there. Argh! so much time wasted in Windows and it was right there in linux.
thanks
