Hi,
I recently bought a Western Digital 320GB Hard Drive to use as a storage device.WD3200JB
I set it up in my computer and noticed that it was only showing 128GB rather than the full 320GB. So I spent some time looking up how to fix it.
On the Western Digital Support page it says the following:
So it recommended updating the 1) Motherboard BIOS, 2) installing SP1, 3) and updating the IDE controller.
I have an old Asus A7V Mother Board, the one shown here.
I went to the Asus site to update the BIOS and downloaded the 1011 version which gave a description of, "A7V BIOS 1011 Support 48-bit HDD." On the POST start up it shows the 1011 version.
I had Windows XP Service Pack 1 (SP1) installed.
Up to this point it still didn't show the full size of the Hard Drive. In my Mother board manual it says:
So on the Western Digital site here i downloaded the "Promise Ultra 100 TX2 Controller Card Driver". I believe I am using an onboard IDE controller so in Devince Manager under SCSI and Raid controllers I updated the "Promise Technology Inc. Ultra IDE controller" to the "Promise Ultra 100 TX2 Controller Card " drivers. I rebooted and checked to see if it would show the full size and it finally did!
However, my joy was soon squashed when I started experiencing problems when I would run some video or audio files or turn on my TV Tuner. The audio would start to make some screeching noises while the file played and/or the video would start to jitter. While using my TV tuner the same thing would happen to the audio and video and would even crash the program and comp. I couldn't figure out what the problem was so I reinstalled my TV drivers and software but the problem didn't go away.
So then I went back to device manager and clicked properties of the "Promise Ultra 100 TX2 Controller Card" and rolled back the drivers to the previous version. Restarted the comp and then my video/audio files and my TV tuner would starrted to run fine again. But now the problem was it would only show 128GB of the hard drive rather than the full.
So I can't figure how to solve this problem? What's causing the conflict when i update the drivers to the "Promise Ultra 100 TX2 Controller Card Driver"? Why does that happen to my audio video and how do I fix it?
I hope I provided enough info to try and figure this out.
Any help would be appreciated. Thanks.
Question:
Why is the full capacity of EIDE drives larger than 137GB (128GB binary) not recognized in Windows 2000/XP?
Cause:
The Windows Operating System, Motherboard BIOS, or PCI IDE controller BIOS does not currently support 48-bit LBA (Logical Block Addressing).
Resolution:
48-bit LBA support is necessary for drives larger than 137GB (128GB binary). The following conditions are necessary for the correct functioning of 48-bit LBA support in Windows 2000/XP:
Windows XP Service Pack 1 (SP1) or Windows 2000 Service Pack 3 (SP3) must be installed for Windows or a registry key must be manually added to Windows' Registry. For information about Windows XP Service Pack 1, see Microsoft Article 322389 or for Windows 2000 Service Pack 3, see Microsoft Article 320853.
* The system must have a 48-bit LBA-compatible Basic Input/Output System (BIOS) installed. This includes EIDE controller card BIOSs. Please determine with the computer, motherboard, or PCI IDE controller manufacturer if this hardware supports 48-bit LBA.
UltraDMA100: Comes with an onboard PCI Bus Master IDE controller with two connectors that support four ATA100 devices on two channels and two connectors that support four ATA66/33 devices on two channels. Supports UltraDMA/100, UltraDMA66, UltraDMA33, PIO Modes 3 & 4 and Bus Master IDE DMA mode 2, and Enhanced IDE devices, such as DVD, CD, CDRW, LS-120, and Tape backup drives
