Hard drive transplant? Possible?
Nhyrum
51
I'm looking to do a hard drive transplant from a rig that died(the drive is fine, the mobo died) into a used PC. Is it just plug and play? Even if it's from a dell to another brand PC? What do I have to do to have it boot from the transplanted drive?
It won't, and no.
You will have a whole new OS. It will know nothing about the old applications and shortcuts.
Steam games, maybe.
You'll almost certainly need to reinstall the OS.
It probably will not boot. At all.
Tied how? To the S/N of the mobo something in the bios? If I needed a spare mobo from Dell could it be repaired? (hypotheticaly, I'm sure they don't support a 10+ year old system)
The OS needs to be installed on the system where it will live.
Moving a drive with an installed OS sometimes works, sometimes doesn't. There is no way to 'fix it' if it doesn't work.
Try it.
See what happens.
And then you will run into activation issues. The license from the old system is tied to that original motherboard. It will become deactivated.
It won't, and no.
Steam games, maybe.
