Hello
Lately I have been having issues with my hard drives.
I have 3 hard drives :
Samsung SSD 850 EVO 120GB - My OS/Boot drive
Western Digital Blue 1TB -Main Drive
Hitachi 1TB - Steam drive (Steam and steam games only)
The issue is that at times the steam drive will act up as if it is gone and I would not be able to access steam or make a folder on the drive. I would get the this drive is not located message when attempted to make a folder on that drive. I rested the pc and I would get the "insert boot media and press a key" prompt. Before I would have to turn off the pc and turn it back on again get it to work. Recently when it happen again I pressed Control alt delete and I got into the bios only to show that the main drive ( western digital ) was missing in the hard drive options. http://imgur.com/a/hRiov
So I turn off the computer and ran WD Data Lifeguard Diagnostic for Windows. The WD Blue fail with to many bad sectors when tested
http://imgur.com/a/MSQ4o
and the Hitachi had no issues. And at one time the WD did not show on the Data lifeguard.
http://imgur.com/a/WHDfN
After that the steam drive unaccessible. I even replace all the sata cables with new ones to see if it will fix the issue.
After a turn off everything is back to normal for now. All I want to know if both drives are bad. I have a WD red 2tb on standby and I can replace the WD blue if needed.
My PC Specs :
OS - WIndows 10 Pro
CPU - FX 8320 4.0 ghz
Ram -16 GB
Motherboard - ASUSTeK COMPUTER INC. M5A97 LE R2.0
GPU - MSI Gaming GTX 970
Also I have a CD drive.
Please and thank you very much.
My PC Specs :
OS - WIndows 10 Pro
Ram -16 GB
