I have a custom-built system with components of varying ages. Here is the set-up:
Case: Antec (10 years old)
PSU: Antec Eathwatts 650W (3 years old)
CPU: AMD Athlon X2 64, 3.1 MHz (3 years old)
Mobo: Asus M3A78, Chipset AMD 770 / SB700, PCIe 2.0 (3 years old)
BIOS: AMI BIOS ver. 2301, Date: 10/22/2010 (Last update available)
Video card: Diamond Radeon HD 6670 PCIe 2.1 (New)
OS: Multi-boot, Win XP Pro, Win XP Pro x64, Win 7 Ultimate x64
What happened was, my old video card's fan failed, and I replaced it with the one listed above. But I'm still having similar problems as the old one: Under normal conditions it seems to be okay, but when it's under a heavy load, such as full-screen video or 3D game renders, frame rate is choppy, and after a few minutes it crashes, either with a BSOD or just hangs. The error messages I get state that the drivers keep getting caught in an infinite loop, and the BSOD error (when I get it) is 0x---EA, THREAD_STUCK_IN_DEVICE_DRIVER.
At first, I thought the issue was residuals from the last card's drivers not getting fully removed, but the problems persist, even after doing a clean install of Windows. Here are the things I think *Might* be at issue:
--- PCIe 2.0 Mobo with obsolete and un-updatable BIOS can't handle PCIe 2.1 card (Based on other threads I've seen here on this topic)
--- Hardware issue with Mobo
--- Faulty RAM
--- Thermal problems from inadequate cooling in old PC chassis.
--- Buggy XP drivers (I seem to have fewer problems under Win 7)
--- Or possibly, the new video card is a lemon??
Anyone have any other ideas? What's the best way for me to proceed with diagnosing the problem(s)??
Thanks ahead,
Dave
--- Faulty RAM
Thanks ahead,
Dave
