Hard wired speakers home runner. How to add wifi connection
magspc
4
So house has hard wired speakers in multiple rooms.. Connected to rc 682m Onkyo in basement. Want to have WiFi connection to onkyo controller/amp/receiver. Suggestions.
Best solution is to use a Sonos Connect wired to your receiver.
That will access internet music services and your music files. Free control app for computers, tablets and phones. Your control is not your source so it doesn't need to be on for the system to operate. You can add a ConnectAmp to create separate zones for greater control. Works great.
Another cheaper solution is to use something like this
http://www.parts-express.com/dayton-audio-wfa02-multi-room-wi-fi-audio-adapter-for-ios-android--300-576?utm_source=Retail&utm_medium=Email_Newsletter&utm_content=300-576&utm_campaign=email123115
magspc
4
Your right it is a remote number. The AV/ receiver is a TX-SR605.
I need to be clear. Looking for a way to either connect blue tooth or wifi to receiver. Send signal into receiver so it will play on different rooms. All rooms are connected to receiver. It originally controlled with Logitech harmony remote It has neither WiFi or Bluetooth connection.
