My question is in regards to my Laptop (Acer Aspire 7736G) which I have had for 4 years (give or take). It previously has had problems of rebooting unexpectedly, which was diagnosed as a overheating problem and resulted in the motherboard being replaced by PC World (Which was quoted £120!!).
For a while this fixed the problem but now the issue is repeating itself and the laptop turns itself off after being used for more than 20 minutes and the start-up and general speed of basic tasks are extremely slow comparing to when I first bought it (Which for a 2.2 GHz T6600 Intel Core Duo processor with 4gbs RAM is DEFINITELY NOT NORMAL!!! #ExtemelyFrustrating!!)
I fear there is a deeper issue involving the CPU overheating and in-turn overheating the motherboard and frying both in the process (which PC World failed to detect any CPU issue at all :/ and simply repaced the motherboard) .
My question is should I replace the CPU and motherboard to fix it once and for all which should be cheaper than buying a brand new laptop or scrap it for parts and ebay the parts individualy ?
P.S. The new laptop equivalent would set me back around £500 ish (I need at least an i5 cpu and 17.3 inch screen)
