hardware problem in linux mint
shashi_1
5
I am using windows 7 along with Linux mint (installed recently). About a year ago i found problem with my Ethernet adapter so i buy enter usb to ethernet adapter which works perfectly with windows but in linux it shows adapter in network but shows cable is unplugged. I tried to install windows driver using ndiswrapper but of no use. please help
shashi@shashi ~ $ sudo lsusb
[sudo] password for shashi:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 003: ID 0fe6:9700 Kontron (Industrial Computer Source / ICS Advent) DM9601 Fast Ethernet Adapter
Bus 003 Device 002: ID 0e8f:0016 GreenAsia Inc. 4 port USB 1.1 hub UH-174
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 045e:0084 Microsoft Corp. Basic Optical Mouse
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
shashi@shashi ~ $ sudo ifconfig
eth0 Link encap:Ethernet HWaddr 00:19:d1:8f:6e:94
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
eth1 Link encap:Ethernet HWaddr 00:e0:00:10:c6:39
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:169 errors:0 dropped:0 overruns:0 frame:0
TX packets:169 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:12211 (12.2 KB) TX bytes:12211 (12.2 KB)
shashi@shashi ~ $ dmesg | tail
[ 207.471850] dm9601 3-2:1.0 eth1: link down
[ 207.491845] dm9601 3-2:1.0 eth1: link down
[ 207.511845] dm9601 3-2:1.0 eth1: link down
[ 207.531846] dm9601 3-2:1.0 eth1: link down
[ 207.551847] dm9601 3-2:1.0 eth1: link down
[ 207.571856] dm9601 3-2:1.0 eth1: link down
[ 207.591848] dm9601 3-2:1.0 eth1: link down
[ 207.611849] dm9601 3-2:1.0 eth1: link down
[ 207.631849] dm9601 3-2:1.0 eth1: link down
[ 207.651850] dm9601 3-2:1.0 eth1: link down
