Hi. Sorry for bad english.
My config is:
Core i5 4690K
Asrock B85m
Gtx 1070 msi armor
Coolermaster 650w
Liquidmaster 120lite
After testing cpu stability by prime 95, i saw whea uncorrectable eror blue screen and the pc starting to shut down in every startup even on bios... Then i set down cpu clock to 3.0ghz and problem solved. Now i cant change the cpu clock to its normal values because it will turning down repeatedly.
What is happened to my pc? Im worrying about motherboard than cpu or cpu cooler.
My config is:
Core i5 4690K
Asrock B85m
Gtx 1070 msi armor
Coolermaster 650w
