Hardware virtualization BLOCKED - BIOS or motherboard problem from Dell ????
glnz
55
Hello experts - hope you all had a great and tasty Thanksgiving - but this one is a doozy:
I have a new Dell Optiplex 7010 MT with with 8GB RAM, a 500GB hard drive and an Intel Core i5-3470 CPU @ 3.20GHz – this is a genuine quad core processor with hardware virtualization. I am dual booting Win 7 Pro 64-bit and Win 8 Pro 64-bit.
Also, I have BIOS A16 with the following settings:
Virtualization Support:
Virtualization – Enable Intel Virtualization Technology is ON
VT for Direct I/O is Enabled – ON
Trusted Execution is OFF
HOWEVER, in Win 7 Pro, I am getting ready to do XP Mode but when I first run the havdetectiontool.exe from Microsoft, it says “Hardware-assisted virtualization is not enabled on this computer”.
Hardware virtualization should be working but something is blocking it – and it’s some type of weird BIOS - hardware problem.
The MS havdetectiontool can create a detailed report - and I am pasting it below. BUT I HAVE ALREADY POWERED DOWN AND UP THE MACHINE MANY TIMES WITH THE ABOVE BIOS SETTINGS. Something is wrong. What is it?
This is the full report:
Intel VT or VIA Centerhauls processor.
System CPU supports Hardware Assisted Virtualization.
Setting up driver.
The file "C:\Users\glnz Admin\Downloads\sources\amd64\\detecthav.sys" is signed and the signature was verified.
Driver installed.
-------------MSR Details------------------
Number of Processors in the system = 4
Information for processor 0 :
VmxProcessor IA32_FEATURE_CONTROL MSR value = 0x000001
VMX Enabled Bit not set
TXT Enabled Bit not set
Hardware Assisted Virtualization is not enabled in the BIOS
Hardware Assisted Virtualization is not enabled in the BIOS.
Please enable "Intel Virtualization Technology" in the BIOS, power down the computer completely, and then rerun the tool on power up
Information for processor 1 :
Information for processor 2 :
Information for processor 3 :
Proc VMXLock VMXEn TXTBit
0 1 0 0
1 1 0 0
2 1 0 0
3 1 0 0
-------BIOS INFORMATION-------------------
Number of values: 15
(01) BiosMajorRelease : 4
(02) BiosMinorRelease : 6
(03) ECFirmwareMajorRelease : 255
(04) ECFirmwareMinorRelease : 255
(05) BaseBoardManufacturer : Dell Inc.
(06) BaseBoardProduct : 0GY6Y8
(07) BaseBoardVersion : A03
(08) BIOSReleaseDate : 09/09/2013
(09) BIOSVendor : Dell Inc.
(10) BIOSVersion : A16
(11) SystemFamily :
(12) SystemManufacturer : Dell Inc.
(13) SystemProductName : OptiPlex 7010
(14) SystemSKU : OptiPlex 7010
(15) SystemVersion : 01
BIOS Vendor : Dell Inc.
BIOS Version : A16
System Manufacturer : Dell Inc.
Final returnValue = 2
Send SQM data to Microsoft.
The SQM machine ID already exists
The SQM user ID already exists
Received SQM upload callback:result 0x0
Current file C:\Users\glnz Admin\AppData\Roaming\Microsoft\HAV Detection Tool\HAVDetectionTool.sqm
HTTP code: 200
►SO WHAT TO DO ?? Hey, Dell, did you make a dumb mistake in the BIOS?
►MORE INFO:
I ran an odd test from Intel called BITS, and it showed an error in the MP Table and two errors in MSR. Don't know what that means, except that "MSR" shows in the "havdetectiontool" results I posted above.
Also, I strictly followed AGAIN the instructions above in the havdetectiontool test -
1) changed the BIOS to DISABLE the two virtualization options, did a complete power down, waited, pulled out AC plug, waited, pushed power button to discharge the capacitor, waited, connected the AC cord, waited, powered up, ran the havdetectiontool test, got the same results.
2) changed the BIOS to ENABLE the two virtualization features AND the Trusted Execution feature, did all the same power down and back up recycling and got an immediate boot error: "Alert! Invalid Trusted Execution Technology Configuration. Please refer to the Trusted Execution Technology Setup option helptext for details." But I have no idea where that helptext is. In any case, it is EXPECTED that Trusted Execution not work. But surprised it prevented boot-up.
3) Went back into BIOS, turned OFF Trusted Execution, left ON the other two virtualization options (so I'm back where I started), did the whole power off wait AC out power on again, booted OK, but same “Hardware-assisted virtualization is not enabled on this computer” message from the MS havdetectiontool test - back where I started.
Big pain in place where I sit on Michael Dell's nose.
Are you awake after reading this exciting saga? Any ideas?
_________________________
► MORE INFO:
The Optiplex 7010 is dual-boot. At the moment (for this update), I'm in my Win 8 Pro 64-bit OS. Its "System Information" shows the following four lines:
Hyper-V - VM Monitor Mode Extensions ... Yes
Hyper-V - Second Level Address Translation Extensions ... Yes
Hyper-V - Virtualization Enabled in Firmware ... Yes
Hyper-V - Data Execution Prevention ... Yes.
I am not familiar with Hyper-V, and I certainly didn't install it on my own. I don't know why there are any references to it. But, anyway, do these four lines mean anything?
Does the machine's DEP prevent the use of hardware virtualization?
►Not an answer but a really weird development.
All of the above bad news was from running havdetectiontool.exe from Microsoft while in Windows 7 Pro 64-bit. HOWEVER, when I booted into my Windows 8 Pro 64-bit, the havdetectiontool.exe says I DO have hardware virtualization!!!
So, not enabled in 7 and yes enabled in 8 - ON THE SAME PC WITH THE SAME BIOS SETTINGS !!!!!
What is this? What is the problem?
I need it OK in 7 because I want to do XP Mode in 7. What is the crucial difference between 7 and 8 on the same PC ???
One more detail: When I first tried to run the havdetectiontool.exe from Microsoft while in Windows 8, it gave me an error message that it could only run in 7, so (while staying in Win 8) I set its Properties to compatibility for 7 and Administrator privilege level. That's when it told me that hardware virtualization IS enabled. But when I ran exactly the same tool again in 7, I got the negative info posted above.
Help !!!!!
► Not answer but MORE INFORMATION -
While in Win 8, I re-ran the verbose log version of havdetectiontool.exe. The results are below. Note the line
VmxProcessor IA32_FEATURE_CONTROL MSR value = 0x000005
That's different from the same line when I'm in Win 7, in the first post above.
How do I get to 0x000005 when I'm in Win 7??
Here's the full report - please compare it to the report at the top above when I'm in Win 7 and it doesn't work:
Setting up driver.
The file "C:\Users\glnz Admin\Downloads\HAVTool\sources\amd64\\detecthav.sys" is signed and the signature was verified.
Driver installed.
Hardware Assisted Virtualization is enabled in the BIOS
0 1 1 0
1 1 1 0
2 1 1 0
3 1 1 0
(11) SystemFamily :
BIOS Version : A16
Final returnValue = 0
HTTP code: 200
► What else is different from the first report above? What has to be changed in Win 7 to make it work?
