Haswell Processors with Alienware Intel® X58 ATX Motherboard possible?
thanks for the reply.
shame to hear that.
do you think it would be worth changing the motherboard?
or would this processor do?
http://www.scan.co.uk/products/intel-core-i7-3930k-enthusiast-unlocked-s-2011-sandybridge-e-six-core-32ghz-12mb-smart-cache-130w-re
or are there better processors? im just trying to find the best possibly equipment, money isnt an issue at the moment as i just want to get an understanding of what is there.
thankyou very much
if you have an x58 motherboard, you probably have a decent cpu as it is. the slowest cpu that can fit in that is an i7-920. whatever cpu you have, you should make sure you have a decent cpu cooler, and overclock it. if u do want to upgrade, just change the motherboard.
