Haswell Refresh vs Ivy Bridge power consumption
tzily2
15
Hi, my old ivy i3 died and this new i5 4460 just came in today.
I was wondering if anyone has any real info on the power consumption regarding the two technologies, in full load and no overclocking of course.
AdmiralDonut
837
142
That's the TDP, not it's power consumption. Consumption on idle for the i5 4460 should be around 55-61 watts depending on the chip, and around 156 watts under full load. It being a non-K series CPU means that there will be no overclocking anyway, so that 156W maximum should account for turbo speeds as well.
EDIT: I shall correct myself. The i5 4460 consumes just 44W on average at idle, and 122w at full load running Linpack, as detailed here:
http://www.xbitlabs.com/articles/cpu/display/intel-haswell-refresh_6.html
FURTHER EDIT: Here are the details for the Ivy Bridge counterparts, from tests conducted by the same people as the previous link:
http://www.xbitlabs.com/articles/cpu/display/core-i5-ivy-bridge_9.html
AdmiralDonut
837
142
Following on from my previous post it would seem that, for non-K series CPU's, the only real difference between the Ivy Bridge and Haswell i5's is that the Haswells use less power at idle speeds than their forebears. To reach this conclusion I have compared the i5 3550 and the i5 4460 as I believe they are the two closest CPU's from each range in terms of speed and TDP.
EDIT: For the sake of completeness, here are the specifications from the ivy bridge i3 range:
http://www.xbitlabs.com/articles/cpu/display/core-i3-ivy-bridge_7.html#sect0
As you can see, the i3's all consume between 60-62W in idle and 84-87W under full load. Comparatively, the i5 is just as energy efficient as the i3, given that it contains two more physical cores than the i3.
You re messing up the CPU and the system consumption
AdmiralDonut
837
142
Which is still more of an accurate representation than the TDP.
Disagree , different video cards different consumption .... my i3 mobile is idling at 5W .
AdmiralDonut
837
142
Does TDP tell you the idle wattage now? Fascinating.
Similar threads
