Have chosen 3 mobo's need help to finalize please
belveder
42
I have chosen 3 motherboards after reading tons of reviews all over the web (although reviews are never as good as forum feedback) to replace my Gigajunk one
So, could I please have some advice or input into which one would be best for my system
1 / Asus P5k Deluxe WIFI
2 / Abit IP39 Pro
3 / MSI (oh ah heck I forget the model :ouch: ) the one with the rollercoaster heatsinks :)
Any help appreciated muchly
Intel Core 2 Duo E6850 CPU
2 x Kingston Hyper 2 GB Kit memory 1066MHz
Gigabyte GA-N680SLI-DQ6 RV2 Mobo
Razer Barracuda AC-1 Digital Audio Card
XFX PCIe 8800GTX xXx Video card
Thermaltake 1000W Toughpower PSU
WD 250GB SataII HD
2 x WD 500GB SATAII HD
Compro T750 HDTV Dual Tuner PCI Card
Thermaltake Bigwater 745 water cooling
Samsung 226BW 22" monitor
Samsung Syncmaster 913 19" monitor
Silverstone TJ07 Tower
Logitech G9 mouse
Razer Copperhead mouse
Razer Tarantula keyboard
Logitech Z680 digital speakers
If it is the Abit IP35 Pro I would recommend that........or the Asus
Might I also suggest a Gigabyte board........the DS3R is good/ or the DS4 if you want a more high-end
I particularly don't like the MSI
I have a Gigabyte board which supposedly supported my system but now longer does, this is why I am looking for another board
The IP35 Pro does look like the better one, I put the Asus 1st though cause of the WIFI & extra usb ports at the back, I'll leave it between them 2 cause on one or two reviews they warn that the MSI may have trouble with large video cards.
Performance wise is their much difference? I don't care to much about support as I use forums for any help, get better help than any company
What doesn't it support?
Either Abit or the Asus, if your wanting my input.
thanks for the help, I ended up getting an MSI P35 Platinum Combo, love it, works like a dream, I will never go beck to Gigajunk again, it's not so much the faulty motherboard, anybody can have that problem, but the service and non existent RMA was pathetic.
Also been leaning towards the Abit ip35 pro but it doesn't support ddr3 and the board is a little expensive.
TC :hello:
