I primarily work on photos in Photoshop CS5, and I play a few games on the side (nothing too intensive). I want a computer that will last at least 4 years. I have most of the parts picked out, but I'm unsure if they are all compatible/if they are the right fit for what I want to do. Here are the parts:
CD/DVD Drive: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Case: Antec DF-85 Black ATX Full Tower Computer Case
Hard Drives: 2x Western Digital VelociRaptor WD4500HLHX 450GB 10000 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Graphics Card: ECS NGTX570-1280UI-F GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
PSU: CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power ...
RAM: 2x G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
Aftermarket CPU Cooler: ZALMAN CNPS9900MAX-B 135mm Long life bearing CPU Cooler Blue LED
CPU: Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor
Motherboard: GIGABYTE GA-Z68XP-UD5 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
I know that the socket type of the motherboard matches the CPU, the pin size of the RAM fits in the motherboard, and that's about it. This is my first build, any advice would help. Oh and I plan on overclocking the CPU, that's what the CPU cooler is for.
Thanks in advance!
Thanks in advance!
