I was installing an SSD the other day and I was trying to find ways to zip tie it and suspend it in the drive bay. So I zip tied the sata power cable to one of the PCIe connectors that go into my video card. Turn on the computer, and it flashes for a split second and nothing. Fans spin for a bit too.
After various troubleshooting I decide to take out the GPU and try starting it, and it starts right up. I thought I had solved my problem here..so I put the GPU back in and start it right up and its fine. Or so I thought. I wasn't getting a video signal so I touched the HDMI cable and it was hot af. I looked down and the power supply cable was literally melting all the way to my power strip.
I know I must have messed something up with the zip ties. My problem is I don't know what exactly is fried. I think it's either the power supply or the GPU itself. Can anything else cause that such as bad motherboard or something? I'd hate to buy a new video card just for it to fry again. I need some guidance here so i don't waste a ton of my hard earned money
Cant say I have ever seen that happen before! What is the model of your psu? That is almost definitely the problem. Impossible to say if anything else has been damaged though. Only way to tell is to try it with a working powersupply. Unless there is visual damage to the components or something.
