hi the good people of toms and good day.
ive just purchased a cooler master seidon 120v and im not 100% sure if ive installed it correctly?
i used the cooler master paste provided and the amd fittings which all went together with ease!
now this is where im confused? as the manual is crap! lol
i went and plugged the 4 pin fan cable into the 4 pin cpu header and plugged the 3 pin pump into the only other header on my mobo (4 pin).
i then went in to the bios and changed the fan settings both to full! as i cant control the speed! no other way? even with speed fan i only see my gpu fan speed? no cpu fan?
the blue led status light comes on and stays on! (i think thats normal)
im not finding it very loud but im sure i can hear a little water treacling about if i stick my head in the case lol so i think it is pumping water?
since installing ive checked my temps with speccy and gigabytes easytune 6 (for my motherboard)
and the temps difference between them both are high!!
pc idle before cooler was added...
speccy 60-70`
easytune6 35`
pc underload
speccy 80`+
easytune6 55`
pc standing idle after installing cooler....
speccy 50`
easytune 6 25`
pc under load
speccy 80`+ and i mean it hit over 100` lol
easytune 41` (i set buzzer to 45` never went off and i havent seen it go over 41`)
i know im not mixing up readings as in both programs they clearly state which temp is what!! cpu,gpu ect, i get the feeling speccy is way wrong? il post my specs below so you know what im working with and i hope ive added everything if not please let me know?
can i just say this is only my 2nd ever build in 5 years so please be gentle with me as im no expert!! lol
green goblin case
amd athlon x4 750k Black Edition
Gigabyte GA-F2A88XM-DS2
MSI R7950 (3072MB) 2PMD3GD5 BE
8gb 2x4gb corsiar xms3 1600mhz
cooler master seidon 120v (fan blowing out the back)
Corsair VS650 650W Power Supply
300gb sata hdd (buying a ssd and a tb hdd soon)
2 x 12cm led fans 1 front intake and 1 side intake blowing on card
thanks in advance people 🙂
speccy 60-70`
easytune6 35`
pc underload
speccy 80`+
easytune6 55`
speccy 50`
easytune 6 25`
pc under load
green goblin case
