Hey guys
I have been building a gaming computer piece by piece.
So far I have the Raidmax Smilodon case (with 500 watt PSU which i know i will need to upgrade)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156098
A Radeon 4850 which i have been using in the computer i have now
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161259
and a Intel Core i7 920 that i just bought from microcenter for $200
The problem is, i only have $400-$500 to spend on the rest of my parts (memory, mobo, HDD, psu, and any cooler)
I also have this Zalman CPU cooler from my last build (but i would rather not use it if possible)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118004
and an IDE DvD burner
my monitor res is 1680x1050 (i may buy a second 4850 to crossfire later on since they are dirt cheap)
and i will probably OC my cpu a bit (possibly to around 3 ghz)
So which parts (ram+mobo+HDD+PSU) do you guys recommend with my budget in mind? ($400-$500)
