Have more fans than connectors
Teche52
7
Hello internet, I'm working on my pc build and discovered that the motherboard I wanted on has 2 fan connectors in total while the case I wanted have 3 preinstalled fans. I heard about fan connectors but don't know how they work. Also how decent are these prebuilt in fans. I'm looking for a cost-effective solution. Thx
Motherboard link: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128565&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Comp case link: http://www.amazon.com/gp/product/B00XD42G1G/ref=s9_psimh_gw_p147_d1_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=desktop-1&pf_rd_r=0SKJ5H86B6TMHYG7VS53&pf_rd_t=36701&pf_rd_p=2079475242&pf_rd_i=desktop
Sorry Friend...
Sorry Friend Your motherdoard dont have any extra fan connectors except the CPU fan connector then how you find 2 fan connector?
if you want to run those three fan you have to buy some connector conversion cable to connect them with your PSU (i.e. SMPS) or fan splitter cables
It says in the motherboard description that there is one cpu fan header and 1 system fan header
Better to go for fan splitter if you want to use System Fan Header
