Have my water cooler put together!! w/ pics =] *DELETED*
the page might be down a lil today because my internet is sucking butt....but I will keep you posted when it gets back up....OK ITS BACK UP :smile:
<font color=green>Without question, the greatest invention in the history of mankind is beer. Oh, I grant you that the wheel was also a fine invention, but the wheel does not go nearly as well with pizza<font color=green><P ID="edit"><FONT SIZE=-1><EM>Edited by civilized on 02/24/03 09:54 AM.</EM></FONT></P>
Looks cool... the case it a little full though. With that green stuff mixed with the water it looks like you're doing some kind of biochemeic experiment in there.
My dual-PSU PC is so powerfull that the neighbourhood dims when I turn it on 😱
Nicely done but please change the text colors on your webpage. Green and Red on a black background hurts my eyes.
<b>99% is great, unless you are talking about system stability</b>
hahahaha thanks man....I wanted to put all of the elements in the case so I wouldnt have crap running through pci slots etc...you know what I mean...the green stuff is just a lil antifreeze....I mixed it 90water:10antifreeze....the cool thing is the antifreeze glows with my led lights :smile: ....sorry about the site I havent had much time to work on it....what colors do you suggest? I will do some benchmarks later this week (3dmark etc)
I read that you were supposed to use a 90/10 mixture....the antifreeze protects the metal parts of the cooler from corrosion etc.....is water wetter a better alternative....if so....what is the best way to remove the antifreeze/water from my system???? without getting anything wet or removing a bunch of parts...I did add a link to my system in my sig
<A HREF="http://dnadesignz.kicks-ass.net" target="_new"><b><font color=green>MY SYSTEM</b></font color=green></A><P ID="edit"><FONT SIZE=-1><EM>Edited by civilized on 02/25/03 04:48 PM.</EM></FONT></P>
If I did manage to remove the antifreeze water....at least there would be some protectant still coating the metal components now...I am mananging to keep my temps very low with my setup...how much should I worry about this?
Water wetter is good, just follow the directions on the bottle. It will protect against corrosion and help with the viscosity of the water, which makes it cool better.
"Apple is more like the French army. They have great style and class, they often get praised for their valor, and they do everything except win."-<A HREF="http://www.overclockers.com" target="_new">Ed Stroligo</A>
could I just add the water wetter to my current antifreeze/water mixture?
I would add a few drops, it says "1 ounce (3-4 caps full)per quart or one bottle per auto coolins system" maybe just a capful to your current setup...
Waterwetter rocks as it protects your water and watercooler for more then corrosion (also abcteria grow and it keeps your pump calcium free). And it even increases the cooling power.
And yes it can be used together with antifreeze but the cooling power will be increased by less then with clear water.
