PLEASE HELP Having difficulty removing 4 pin connector (AOI_PUMP 4 PIN slot) from ROG ASUS motherboard. Please help
I'm building a brand new PC with a ASUS Rog motherboard and stupidly after installing a CPU liquid cooler (the type with fans connected to a radiator at the top of a PC case), I connected the cable from those fans to the AOI_PUMP connector when it should have really been CPU_FAN 4 pin connector. I am trying to remove the connector from the motherboard and it just will not budge, I've tried holding the 4 pin connector at the sides of the plastic and pull up but it just will not move. There is a latch on the connector but I do not know whether to press it IN or use a small flat head screwdriver to push it OUT while I am trying to pull it out via the sides ?
I include a photo of the 4-pin connector that is stuck on the motherboard, as you can see it has other 4-pin connector pins right next to it so access is not great with getting a grip on the sides of the connector etc.
4 pin connector stuck https://ibb.co/WgNnPKB
Also looking at the side of the motherboard at the 4 PIN connectors they seem to have a 'lip' at the top so that would imply that you have to use a flat head screw driver to pull the latch out while simultaneous pulling UP from the sides of the connector BUT I am not sure about this. Please advise. The board is expensive and the water cooler was also (ROG RYUJIN III ARGB and ASUS ROG Maximus Z790 Formula).I'm guessing that if I leave the Water Cooler Fans plugged into the AOI_PUMP socket, it's not the end of the world, the fans will just run at max etc with me not being able to control via the ASUS software, not ideal but there you go. The other cable from the actual pump mount above the processor can go into the CPU_FAN, W+ PUMP sockets (or I read it could have gone into the AOI_PUMP socket) so all is not lost maybe ..?thanks in advance
