Question Having input lag issues
Apr 30, 2019
I am getting input lag when in games even if it is running at 60fps or higher. Such games, Fallout 4 on high settings, GTA 5 on high, Resident Evil 2 RE on high, and Grip on Ultra. Note that when I lower the graphics settings and/or turn off v-sync, the input lag gets better but it is still there unless I set it to the lowest settings. Even on mid settings the input lag is existent. My PC is supposed to be able to run all these games past their minimum and recommended settings. This doesn't happen on games with much lower system requirements, such as Depth. This lag happens whether I use keyboard/mouse or my steam controller. My keyboard mouse and controller are all plugged in wired. I also do not have input/mouse lag outside of these games.
Here are my specs:
PCPartPicker Part List: https://pcpartpicker.com/list/hjvX8Y
CPU: AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor ($116.89 @ OutletPC)
CPU Cooler: AMD - Wraith Max 55.78 CFM CPU Cooler ($39.10 @ Amazon)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard ($75.61 @ OutletPC)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-2400 Memory ($76.89 @ OutletPC)
Storage: ADATA - Ultimate SU800 512 GB 2.5" Solid State Drive ($57.99 @ Amazon)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive ($54.99 @ Newegg Business)
Video Card: XFX - Radeon RX 580 8 GB GTS XXX ED Video Card ($187.89 @ OutletPC)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case ($45.28 @ Amazon)
Power Supply: Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply ($47.98 @ Newegg)
Case Fan: Thermaltake - Riing 14 LED Orange 51.15 CFM 140mm Fan ($14.99 @ Amazon)
Monitor: Dell - S2316M 23.0" 1920x1080 60 Hz Monitor ($180.00 @ Amazon)
Keyboard: Redragon - K552-R KUMARA Wired Gaming Keyboard ($36.99 @ Amazon)
Mouse: SteelSeries - Sensei Wired Laser Mouse
Total: $949.59
Generated by PCPartPicker 2019-04-30 00:36 EDT-0400
Note: My monitor, cpu cooler, and keyboard weren't listed on pcpartpicker so I manually edited them in.
I have tried:
  1. updating all my drivers; (ASRock app shop, usb drivers, keyboard, mouse, display, gpu, etc) the only driver that needed updating was my display and that didn't fix any input lag.
  2. turning off f.lux
  3. checking to see if there are any funky settings on my monitor that are turned on
  4. testing out normal. fast, and very fast response times on my monitor.
  5. double checking to see that the monitor is plugged into the GPU
  6. I have not overclocked my system.
Everything in this build except for the keyboard and mouse is new.
Here are some photos of my Radeon settings.https://imgur.com/a/7FFg558
Here is my benchmark.https://www.userbenchmark.com/UserRun/16590702
Try use the built in fps limiter in the Radeon software to 2fps less than the refresh rate so 58.
With the fps capped, fiddle with a combination of vsync settings in Radeon and game. Like vsync set to on or enhanced in Radeon and in game set to on/half or off.
Vsync does introduce input lag when on as it caps the fps to your monitor's refresh rate so you don't get micro stutter and tearing if fps goes over 60. Vsync caps the fps right on 60Hz and triple buffering can help but it's not perfect. I find capping fps myself couple frames lower sort of acts like a phantom buffer and should help if this is the same issue.
I'll try this out
