Specs:
System Specs:
I7-3770k OC 4.2
H100i cooler
4 120 mm system fans
2 120 mm hd fans
1 Vector 256 gb Sata 6
3 x 3TB Sata Green drives 7200 rpm
32GB of DDR3
PSU is ST75F
VCORE 1.138 on Asus reading CPU-Z shows 1.128
Core Speed 4140
Multi. 41
Temps using Handbrake are steady @ 55-58 C the whole time. Temps seem high for such a low overclock based on the article I read here.
What steps can I take to get the OC up to 4.6-4.8 and not be rocking high temps?
System Specs:
I7-3770k OC 4.2
H100i cooler
2 120 mm hd fans
32GB of DDR3
PSU is ST75F
Core Speed 4140
Multi. 41
