My Pc build is
Intel CORE 2 Quad Q6600
x2 4-4-4-12 Ballistix 800MHz 1GB RAM
x2 4-4-4-12 Ballistix 800MHz 2GB RAM
x2 Nvidia GeForce 8800GTX BFG OC2 (only have one card in at the moment though)
x2 1TB Hitarchi HDD
x1 300GB Western DIgital HDD (Has windows 7 Ultimate 64bit)
Corsair HX 850W PSU
Ok that is my build my problem is as follows.
I have bought the FP-IN9 off of a firned and it was working perfectly for him, but when I installed my parts, I got a black screen. At this point, I unplugged everything except the WD HDD, CD drive, CPU and 1GB RAM. So I had the bare minimum. Still didn't work.
When reading the manual, it said it supported a 20 pin power unit, so I unplugged the 4pin and plugged the 20pin power connector into the mobo. COmputer starts up and the first screen loads.
Problem one solved.
I then plug the 4pin back in so I now have the full 24 PIN in my mobo. Restart, works well. Ask it to boot from CD (as at this point I want to install windows) doesn't recognise keyboard. I restart my PC again, go into BIOS and then set it to recognise USB keyboards. Restart, I get a black screen.
Reading through the manual further, it said about resetting the CMOS, so that's what I did. Problem solved, I have now installed windows, and am looking at it.
I then plug the rest of my RAM in and my other HDD and restart. I got a black screen. I then again reset the CMOS and power up, computer works fine. I read on, and it said another way of resetting the CMOS, so I shut my PC down and tried it.
It was unplugging the 24pin connector and the 6 pin connector from the mobo, take out the battery and reset the CMOS for 1minute with all that unplugged. THen plug it all back in and put CMOS to correct position. I done that, computer starts up fine. I then restarted to see if it worked, it hadn't. I then shut my PC down, reset the CMOS and it worked.
I tried loading the failsafe defaults, I was stuck on the first screen, tried loading optimazed defaults, but when restarted got black screened so had to reset CMOS yet again.
On the menory test, everything is appearing as it should be bar the RAM, the RAM is appearing as 533MHz instead of 800MHz. When I enter the BIOS, the RAM and the CPU is getting enough power. (at this point i decide just to check to see if everything i getting enough power, so exitied without saving, and PC loaded fine). I then thought well what happens if I set the correct Hz to the RAM will that fix it. So i set the correct Hz didn't work, as when I saved the new BIOS settings I got a black screen. SO I then had to reset the CMOS loosing the changes I have saved to my BIOS.
I then decided to flash the BIOS. So i loaded up windows, installed the flash hardware, but my BIOS is already up to date.
SO I am now stuck on what to do. I can get a new BIOS chip, but that's going to cost as I have to inport from the netherelands. So, please, does anyone have any ideas, I'm raelly stuck on what to do.
Thanks for reading
x2 1TB Hitarchi HDD
Corsair HX 850W PSU
Problem one solved.
Thanks for reading
