hi everyone! i need help with my motherboard because i'm getting the following problems:
1. Can´t select AHCI mode in BIOS- results in Bluescreen when booting Windows. ( Even if you change Name value to 0 in Hkey-localmachine[...]
2. DRAM in BIOS is shown as 1333hz even when selecting the right. (1600 HZ)
3. When Installing USB or MEI driver, after restarting PC all USB ports get deactivated- no way of doing anything. Only possibility is to either reinstall windows or to Recover.
4. After some weeks of running, PC fails to find Harddrive. Only way it actually finds the SSD is by pressing the MEMok Button onboard.
5. GTX 980 Strix oc ASus- loud Coil whine, specialy when playing games. Loudness depends where you look ingame. The higher FPS the higher the Coil whine. Limiting FPS to Monitor Hz doesnt help.
6. Hardware Manager shows problems for :
PCI-Communicationcontroller (simple)
SM BUS-Controller
Unknown Device
USB (Universal Serial Bus)- Controller
Can´t load/find drivers.
By installing e.g. the driver it results in Problem No. 3 -> Recover again.
Usb Devices like mouse, keyboard, headset are useable without driver so they´re not specially installed.
these are the CPU-Z specs of my pc.
hope someone will help me because it getting sad :/
SM BUS-Controller
Unknown Device
