having problem maybe powersupply
Talahashi
16
hi, i recently bought parts and put them together. when i try to power up my computer front fan light would flash once and computer won't start. can someone tell me where f67 cable go its from the case
my parts are
z170s sabertooth mb
i7 6700k cpu
hyperx ddr4 ram 4x8gb 2666mhz
500 gb samsung 850 evo ssd
wd black 7200rpm 1tb hdd
lg dvd rw od
evga 850w g2 psu
gtx 970 msi gaming oc gpu
thernmaltake 300 water 3.0 extreme liquid cooling
CM storm stryker case
I have no idea what cable that is for. Where does it go to? It looks like maybe its a fan plug, can we see the end of it (like where it plugs in). Where do you get "F67" from?
Are all your case fans plugged into the board?
EDIT: just looked through the manual that cable is not shown, maybe it goes directly to one or more of the fans? It doesn't look like any cable that would go to the PSU or motherboard. That case's fans work off a fan controller which needs to be plugged into the PSU with a 4 pin flat molex connector.
F67 cable? I think you have the name of it wrong, how about a picture? Also the case manual should show you this.
As for it not powering on, the motherboard likely has a short, did you install all the standoffs into the case and then make sure to screw the motherboard to all of them?
well the place i bought parts from run a test for cpu mb ram and they said its in good condition. but they didnt test my psu. so im gona try different psu i have at home after work and see if it works or it could be my cabling is wrong im pretty newbie at it so 🙁
If they tested those things and they were not in the case then my answer is your issue, something is likely shorting it in the case, either a standoff that is not screwed in (and touching the board somewhere, maybe even where there is no screw hole) or possibly you have your case buttons connected wrong.
Your PSU I am pretty sure is perfectly fine, you can test your board outside the case to be sure.
