B blessyaokpedzroku Feb 28, 2018 1 0 10 Feb 28, 2018 #1 When i try connecting using the wps push button it will do and tell me there is no Network available whiles there is a network pls what is the problem
Solution popatim Mar 1, 2018 You first need to press the WPS button on your router, if your router has one...
popatim Titan Moderator Dec 2, 2009 39,087 1,025 136,890 Mar 1, 2018 Solution #2 You first need to press the WPS button on your router, if your router has one... Upvote 0 Downvote Solution
