B balson Reputable May 9, 2014 8 0 4,510 May 16, 2014 #1 Hi I am doing oc to my CPU i7 920, I put bclk 160, and multiplier/ratio CPU 20, and memory ratio 8, vcore 125, according to the guide I need to lower the vtt until my system go unstable.. What that means?
Solution Tradesman1 May 23, 2014 The VTT is your MC (memory controller) voltage, you can try lowering it while maintaining stability to help keep heat down
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 May 23, 2014 Solution #2 The VTT is your MC (memory controller) voltage, you can try lowering it while maintaining stability to help keep heat down Upvote 0 Downvote Solution
