Having shutdown problems
G
Guest
Guest
Archived from groups: microsoft.public.windowsme.general (More info?)
Hi group! When I shutdown the computer, it shuts down like it is supposed to.
When I boot it back up, sometimes a blue screen comes up saying that the
system is busy and waiting for the close dialog box to display which it never
does. When this happens, I can not reboot with ctrl/alt/del, I have to
manually turn the computer off and on with the power button on the pc. Then
when it reboots, it automatically goes into scan disc.
Does anyone know of a fix for this? If so, please let me know. I'd
appreciate it!
Ron M
G
Guest
Guest
http://aumha.org/a/shtdwnme.php
Jack E. Martinelli 2002-05 MS MVP for Shell/User / DTS
Help us help you: http://www.dts-L.org/goodpost.htm
http://www.microsoft.com/athome/security/protect/default.aspx
Your cooperation is very appreciated.
"rlm44" <rlm44@discussions.microsoft.com> wrote in message
news:9B9E1388-5E03-4584-BF30-6925A2C394F8@microsoft.com...
to.
never
Then
> appreciate it!
> Ron M
G
Guest
Guest
Thanks Jack Martinelli! I went to aumha.org and found the solution. All I had
to do was to add a windows exit sound. It seems to be shutting down and
booting back up ok. Thanks--Ron M
> to.
> never
> Then
> > appreciate it!
> > Ron M
Similar threads
