Windows 10.
When I connect my Lacie external harddrive it shows up as a unit, but Windows will not give it a volume so that I can access it.
I had the same problem yesterday, and after I contacted LaCie support they insisted that it was a different format and that I had to reformat it. However, after a while it spontaneously appeared as a volume and I could access the files without a problem.
Now, due to a windows update tonight the machine restarted, and once again I cannot access it.
Does anyone recognise what the problem is, maybe? I haven't encountered a problem like this before.
If it's relevant information, it's a 2TB drive and 99% of it is used.
(I have a HFS explorer installed, but I did not use it to access the files.)
